hi all,
below the the file with the content of my CustomFieldNames.xml file. I need to add into code another field, is a custom field, the field name is: gs_MPN.
Could anyone help me to complete the code?
You should be able to store your gs_MPN field into the field “barcode” in GarageSale’s XML format.
Here are the current docs for GS 7:
https://manual.iwascoding.com/gs7/en/Listings_Section-Importing_listings_from_XML.html
