The applescript is not working that much at all.
I have this script to update everything but it doesn’t seem to work to well.
tell application "GarageSale"
repeat with theListing in (get selected ebay listings) #set the starting bid price of theListing to 12.0
set newBidAmt to buy it now price of theListing
set amount to (starting bid price of theListing as real)
set amount to (amount as real)
set starting bid price of theListing to (newBidAmt - 0.01) as string
end repeat
end tell
It changes some, but not everything and has takes a long time to run, since it is executing against garage sale.
Starting with Beta 31, this script should do what you want:
--set the starting bid price of theListing to 12.0
--set amount to (starting bid price of theListing as real)
--set amount to (amount as real)
set use starting bid of theListing to true
end repeat
end tell
