I’m trying to upload two new auctions to ebay, but I keep getting the message, that the item condition has to be set. While researching that error, I found out that this might be related to an item category for which a condition is mandatory. I already tried refreshing my user token.
I think that’s just a follow up error. It seems that eBay thinks that your item belongs to another category and so changes the category (which now requires an item condition).
What you should try is to select another/the correct category. If you also select a condition then you should be fine.
