Hi - using GarageSale 9.0.5
Is it possible to pull info / stock photos from ebay’s catalog automatically? May have a bunch of CDs and DVDs to list, and was hoping that maybe that was possible from a bar code scan. Thanks!
You can use the free “GarageSale Scout” app to scan your barcodes.:
You then import your GSScout items into GarageSale. In the “Product” popover you can select “include additional information” and “include stock photo”. They will then be shown in the uploaded listing on the eBay website.
Thanks! Where is the PRODUCT popover? I’m on HIGH SIERRA 10.13.6. THANKS!
