Is it possible to keep the last used interval between sessions?
Default is 1 day and I prefer 1 hour
You could create a “master listings” that contains all your preferred settings.
Please see the “New Listings” section here:
https://manual.iwascoding.com/gs8/en/GarageSale_Preferences-eBay.html
Thanks for your suggestion Kristian but I never create a new listing from scratch. (I think that is what you are suggesting). I always duplicate one which is similar. Saves a lot of time that way. I guess my post is still open for a solution though.
Regards David
