Barcode Scanner Question
I have searched and looked at the manual, but I do not see how to do this. The manual says “Enter it here” but it doesn’t say WHERE that is. I want to list CDs and enter (or hopefully scan) the barcode. How? Where?? Thanks…
In the “Options” Inspector on the right side of GarageSale’s main window you can define categories, attributes, product and also enter the barcode. Please see the first screenshot here:
https://manual.iwascoding.com/gs8/en/Listings_Section-Setting_Up_eBay_Listings.html
You find the “Barcode” field right below “Product:”.
Aha. OK I see that now. You have to open the Inspector. OK so is there a way to scan the barcode?
