I have literally hundreds of old (2011-present) auctions I would like to get rid of. Is there a way to archive them? Or can I just delete them?
Thank you!
Version 6.9 (603)
Thank you!
Version 6.9 (603)
Hi Michelle,
if you’re referring to auctions (not to auction templates), yes, you can archive them but they will still stay in GarageSale:
http://wiki.iwascoding.com/mediawiki/index.php?title=Auction_Menu#Archive_Auction_Web_Page
Another way is to export their data to CSV files:
http://wiki.iwascoding.com/mediawiki/index.php?title=Auction_Menu#Export_auction_data_to_CSV_file…
You can delete them, too. Don’t forget to empty the trash afterwards.
If you’re referring to auction templates: Use the export command from the FILE menu if you want to save them.
