Clickable link displays as box with ? mark
But it does work. Will it display properly when uploaded?
Thanks!
Hi scoutshouse,
could it be that you have activated the “Create clickable image link” checkbox in the “Insert HTML link in description” panel?
You should only do this if you have entered an image URL in the “Display Text” field there.
Thanks again, Krisitan!
