HI
I am trying to create an Excel (or Mac numbers) file that I can put through a CSV to XML convertor so that I can import a full range of item listing data into garagesale
CSV import seems to be limited to around 8 fields (is this correct?) and so XML seems to give me a lot more options
Does anyone know the format fro the Excel or have a working example
All help appreciated
Sean
