I’m having problems importing my database when upgrading from GS6 to 7. I got an error message that said DB corrupted, contact iwascoding. I shut down GS, started up again and it found an old DB, one that was apparently created when I tested GS7 over a year ago. So now I have an invalid, very old database instead of a conversion to my latest, which has changed considerably in this timeframe. Not sure how to recover the old database, all I see is the com.iwascoding.garagesale7 file. in the library. Can someone please tell me location of my previous and up-to-date GS6 database? Thank you!
Can you please check #19 “How do I re-import my GarageSale 6 library?” in the FAQs here?:
https://www.iwascoding.com/GarageSale/Support.html#FrequentlyAskedQuestions
Always great support here, that worked perfectly. Thank you Kristian.
