Crashing synching
Hello,
pause synch, enable again and press “synch now”. In first computer it finished, in second computer it crashed as soon as before it finishes. The result is a not complete synch with listings started in first Mac not moved to the correct folder in second Mac. I just sent you the crash report…
In the meanwhile I will stop synching and think about restarting from zero, I wait for a fix.
Federico
same thing happens here. Seems like sometimes I can sync but not completely. Then I go to resolve issues and select the database as the correct… and crash
