Continuing the discussion from Default auction settings/template using GS Scout:
I setup my default settings using GS7 Preferences>eBay>Copy all setting from this listing:
I dropped a master listing template in the dropzone area.
I then imported from GarageSale Scout.
Issue:
It appears almost everything imports fine except the text right below Item Specifics. The pictures import just fine but the text that I have in the Master template does not get imported. This text us usually just above the pictures. The only text that ends up being above the pictures after the import is the Latin(?) verbiage.
I’ve tried deleting the Master dropzone area, restarting GS7, re-dropping the template, importing 1 selection from Scout, importing 4 selections, etc. All seem to ignore the text I have set up in the Master template.
One thing I did notice is whatever I put in Scout>Notes area DOES replace the Latin verbiage.
My workaround is easy, just a copy/paste from the Master I want to use to the ones I imported.
Anyone have some guidance?? Thanks in advance.
-les
