The Deleted Listings folder with trashcan is located below all the other folders.
To empty this one currently needs to:
Open a contextual menu using the Control key and select Edit > Erase Deleted Items.
Select Edit > Erase Deleted Items from the top menu bar.
After this is done the left column auto scrolls down to the bottom and this folder is selected.
I then need to scroll back up the place I was in the column of folders, wasting time.
I’d like this automatic scrolling and selection of the trash folder disabled.
If the select a listing and press the Command and D keys a duplicate of the listing is created below the original and both are unselected. The same occurs if I select the listing and use Edit > Duplicate from the top menu.
So if I want to duplicate the same listing template five times I have to reselect it five times and use one of the above menu option or key combination five times. There should be a menu option or key combo whereas I can instruct GS to create 5 copies. Perhaps by typing “5” into a popup window that automatically closes after you type the quantity in.
