so now again my mistake is there, which I had described to you (in a topic, which was closed automatically after 10 days)
I have two categories, there are no subcategories anymore …
As already written, that happens very often and not only in the categories
So, after you duplicate a listing, the category it uses disappears from the category browser?
Any chance you can capture the lead up to the bug in a screen video using QuickTime player? That’s what it would be easier to replicate and fix for us?
If not, what was the specific category you selected and what macOS version are you using?
I just tried to open Garagesale to record the screen. Garagesale has updated the categories when calling an existing auction. And now some categories have disappeared again. I have not even copied an auction or done anything
alone when I open the garage, the categories are missing. Yesterday, everything was not there anymore.
For existing and current auctions is written then:
eBay updates their category data pretty often. If they remove or move a category, it might be needed that you re-select it in GarageSale. GarageSale can’t display a category that does no longer exist.
I’m sorry, but it’s enough. I update the categories in Garagesale, but they do not appear anymore. Only after I delete my account in Garagesale and reload the category directory and then reload it, then they are all there again.
I would like a solution, otherwise the money back
Most likely you are running into write errors when the updated eBay category data is saved to your hard disk. Once the category data is release from RAM, and GarageSale tries to reload it from the disk, the data is not there anymore.
Have you tried running Disk utility and check your hard drive for permission or catalog issues?
If none are found, can you send me your category data file once you re-downloaded it and it appears correct in the category browser? This way we could check if my theory holds true and there is indeed data missing. Here is how to do it:
In GarageSale, choose “Help” > “Open Library Folder”
