Hi, I installed GS 7 yesterday - all fab but just one problem. The Find option on the drop down, all it’s options are greyed out so I cannot do a search. Am I missing something here? The only option that is not greyed out is the bottom one - Jump to Selection.
If anyone could help me that would be great, thanks,
Thanks for your reply, it still doesn’t work I have tried every which way but loose and I cannot to get the options to un-grey at all in any circumstance, I have gone to using the search but use the find a lot. Not sure why it doesn’t work for me.
Could you perhaps post a screenshot here of how your GarageSale window looks like while the Find Options don’t get enabled?
You can take a screenshot by pressing cmd-shift-4 on the keyboard. This creates a Screenshot file on your desktop which you can simply drag into a post in this forum.
