Hello,
is it possible to use folders to organize and tidy smart groups in the listing section? I have a long list and each time I show all smart groups it is a bit confusing, some folders would help…
Thank you for any info
P.S. I take the opportunity to ask you another info: is it normal that I can’t I delete listing in smart group? Why??
Because smart group membership is determined solely by the smart group rule. It would be inconsistent, if some listing would match the smart group’s criteria but no appear in it, because the user deleted them from it earlier.
