I use this program for my business and have about 12,000 listings split between 3 different computers. At random times the program will just freeze up for random periods of time. I can force quit it and re-open the program but it will usually happen again within 10 minutes of re-opening it. This usually happens when I have ending listings but It has also happened on a computer with a fresh install of garage sale. Has anybody else had a similar issue and what did you do about it?
Can you please send an e-mail to the GarageSale support team at garagesale@iwascoding.com and attach any Crash report files from GarageSale located in your user’s home directory Library/Logs/DiagnosticReports.
If you don’t see a folder called Library in your home folder, you have to “unhide” it using the View > View Options command.
I just sent an email.
