GarageSale 7.0.14 Beta 1 Released
The first beta version of GarageSale 7.0.14 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.14b1.dmg
What’s new in GarageSale 7.0.14
  • adds graphical indicators in listing editor mode for gallery images and images with captions
  • fixed an issue where the ‘Exclude Locations’ list in the shipping panel remained empty
  • fixed an issue where incomplete category data was downloaded from eBay when no or an invalid eBay token was available
  • the list of fields selected to be searched from the search popup menu is saved
  • when manually re-listing items, the re-listed listing is now selected instead of the original listing
  • re-listed listing are now inserted into the hierarchy at the correct position
  • fixed a possible crash during re-listing, when the re-listed became part of a smart group
  • improved ‘Reveal Original’ command for smart groups items
  • fixed a possible crash during re-list when no account token is present
Thank You!
Thank You!!
Thank You!!! Although, the “Deleted Listings” Group is still “opened”…
Thank You!!!
Well, that was sure fast!
Uhm do you mean that after relisting a listing, the new and active one is selected (and so the output folder opened?)??
Yes. Doesn’t this work for you?
I hope not! I mean, if it is how I imagine, I don’t think it’s very a good idea. It’s quite messy if every time I relist something, the output folder is opened (then I have to close one by one again). I always had troubles about this and considered it was an issue (something like it, I suppose: https://www.dropbox.com/s/3fd6sm4nagp3qwx/relisting.mov?dl=0 it’s a very old video I put somewhere in the forum, the relisting of multiple listings opened crazily folders and folders and make the usability impossible)… did I understand correctly? Anyway this is just a personal suggestion, I suppose someone else find it suitable, a more reason to leave relisting (recently changed every listing to GTC so it won’t be a problem for me).
