GarageSale 7.0.5 Beta 2 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.5b2.zip
What’s new in this Beta version
- fixes a crash when selecting multiple items with differing destination folders in the auto-restart setting and switching to the “Advanced” tab in the listing section
- addresses a problem where the auto-relist feature would only re-list the initial listing automatically, but not subsequent copies
- product search now searches on the site of the selected listing instead of the default site selected in GarageSale’s preferences
- reports are now searchable by name
- preview automatically reloads when videos are added or removed from the listing
What’s new in GarageSale 7.0.5
- dragging and dropping images from the Photos app on macOS 10.12 Sierra works again
- Orders section: added menu command to show shipping address in Maps app
- Listing section: added image context menu command to import images directly from Camera
- fixed possible crash when items referenced by smart groups where no longer present in the database
- pressing the return key in “Edit Image URL” panel now closes the panel instead of inserting newline character into URL
- right clicking on placeholder image in listing preview now shows a context menu containing the “Add URL Image” command
- fixed a possible crash when computing variation quantities during auto-relist of a variation listing
- fixed a possible crash when opening the “Advanced” tab in the listings inspector
- initial switch to the “Advanced” tab should be much quicker now
- eBay messages created in GarageSale should now be send quicker if GarageSale is busy downloading other eBay data
- fixed a problem where a listing’s state wasn’t properly updated when eBay listing data was received
- added additional safeguards against too many listing being started during auto-relist
