GarageSale 7.0.8 Beta 2 Released
The beta 2 of GarageSale 7.0.8 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.8b2.dmg
What’s new in GarageSale 7.0.8 Beta 2
  • launch control window now stays open when background tasks finish
  • no longer shows duplicate errors when inserting incorrect numbers in value fields in the inspector
  • all documented commands in GarageSale’s design language should work now
  • improved error handling when listings from GarageSale 6 fail to import
  • added German localization
  • fixed some crashes
GarageSale 7 requires OS X 10.10 or later
@ilja is it normal???
It’s all fine, it’s just a new panel introduced in 7.0.8b2.
Ok fine, thank you…
