The eighth beta release of GarageSale 7.0.8 is available for you to download from the URL below, or from the built-in updater if you are running a previous beta version:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.8b8.dmg
- HTML links created with the “Insert HTML Link” command will now open in a new browser window (as required by eBay’s new active content rules)
- the preferences for moving & duplicating items when starting auctions are now saved separately from those used when re-listing (this should prevent users who overlooked their still active ‘Move To Trash’ setting used when re-listing from getting confused next time their listing ‘vanishes’ into the Trash after uploading them to eBay
What’s new in GarageSale 7.0.8
- when GarageSale’s free image server is used, GarageSale uses the https-protocol to embed links to your images into the item description (as will be the eBay requirement for all image links, soon)
- the image context menu in editor mode now shows the image’s dimensions
- updated ‘Icon Legend’ in the Help menu
- added support for a different flavour of eBay TurboLister CSV files
- remembers the time interval you last selected in the built-in scheduler and uses it for new events
- will display a local error when user enabled eBay’s ‘Global Shipping Program’, but lists in a category where GSP is not supported
- addresses a crash during outline view manipulation (e.g. duplication or re-listing) under low memory conditions
- fixed crash when trying to end a listing, for which GarageSale does not have account information
- fixed an issue when verifying your PayPal API signature
- fixed an issue where the ‘Download images’ flag in the ‘My eBay Import’ panel was ignored
- fixed a problem which caused not all charity organisations supported by eBay to appear
- fixed a bug that caused the launch control window to close when listings were uploaded by a background task
- no longer shows duplicate error panels when entering incorrect numbers into value fields in the inspector
- a few documented commands in GarageSale’s built-in design language didn’t work. This has been fixed
- improved error handling when listings from GarageSale 6 fail to import
- added repair mode to relocate listings that are no longer present in GarageSale’s current group hierarchy (hold down control key on app start to enable it, checking your database can take several minutes)
- fixed a rare problem that could occur when a buyer ordered items from the same listing in two or more transactions with a single eBay order
- Preview: repaired display of product details, now shows item location, cosmetic improvements
- Pro Designs: The „More“ button now works again in the eBay iOS app.
- we finally found and fixed a bug that could cause wrong listing titles to be inserted when switching between listings
