Beta 47 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b47.zip
- fixed memory leaks
- updated English Help
- updated Italian and French localizations
- label in ‘Launch Control’ window shows correct status when in revise or re-list modes
- listing stays selected when ‘Move after launch’ option in ‘Launch Control’ window is activated
- all url-images are included in AddItemRequest if pictures on targeted eBay site are free
What’s new in GarageSale 7
- a new custom database engine, which deals better with large amounts of data and allows us to adapt to eBay changes more quickly
- added support for specifying shipping insurance cost on eBay Italy and France
- added 4 new designs
- when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
