GarageSale 7 Beta 10 Released
Beta 10 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b10.zip
We’d appreciate your feedback, so if you have a few minutes to spare, please give GarageSale 7 a try. Your GarageSale 6 installation will not be altered by trying out GarageSale 7.
  • when choosing a product for a listing without category, GarageSale tries to select the appropriate category for your listing
  • fixed an issue in the GarageSale 6 importer that could lead to wrong order statuses, and thus wrong item counts in order smart groups (see below for instructions on how to re-import your GS 6 library)
  • works around an eBay error when listing in variation-enabled categories that require a product code, but your item doesn’t have one
  • an inventory item’s cost are now transferred to the cost field of a new order for listing linked to the inventory item
What’s new in GarageSale 7
  • much more
Upgrades and Pricing
Migrating from GarageSale 6
How to re-import your GarageSale 6 library again
  1. Export any listing you created in GarageSale 7
  2. Quit GarageSale 7
  4. Restart GarageSale (make sure you using beta 8)
  5. Import any listings you imported in step #1
What’s still missing
  • localized user interface for languages other than English
  • a user manual
  • CSV import for inventory items
  • XML import for listings
Been getting this for a while, through the Betas not sure when it started. Presume its when in Live mode:
