Beta 11 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b11.zip
- added a preference setting to Flash to prevent Flash plugin crashes
- the preview of your listing footer shows up in the Preferences panel (again)
- when eBay returns an HTML message in response to a listing verification, GarageSale can now show this message inline
- when switching between sections while a search result is being show, the search result is removed from the outline and all items are shown instead
- fixed a crash when switching between sections while a search was still in progress
- auto updater now checks more frequently for new releases
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
How to re-import your GarageSale 6 library again
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale (make sure you using beta 8)
- Import any listings you imported in step #1
What’s still missing
- a user manual
- CSV import for inventory items
- XML import for listings
