Beta 22 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b22.zip
- only categories with paths matching all words in the search field are shown in the category panel during search (you need to update your category data manually by clicking the ‘sprocket’ button in the category panel to make search functional again)
- fixed crash when moving already listed items to the trash when “Start Listings” command was invoked
- fixed a bug in the GarageSale 6 importer, that could lead to crashes when listing items or variations linked to an inventory item with images (see below for instruction on how to re-import your GS 6 library again)
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
