Beta 23 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b23.zip
- example AppleScripts can be viewed from the Help menu
- added menu commands for editing categories and item attributes
- fixed a problem with entering double quote characters in the title field of the preview mode
- fixed a crash when deleting items from the context menu
- fixed a crash when selecting items
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
