Beta 24 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b24.zip
- launches faster
- faster reactions to selection changes in the outline view
- displays progress when generating preview takes longer because category data is being updated
- added support for Endicia shipping software
- media browser window opens automatically if left open when last quitting
- added menu command for editing buyer requirements
- added menu command for editing return policy
- added menu command for editing shipping options
- added menu command for editing payment options
- added menu command for editing product details
- fixed a crash when the “only show exact matches” search option was selected
- the eBay item number in the live view inspector can be copied to the clipboard
- store popup in inspector is hierarchically sorted by alphabet if option was selected, instead of flat list
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
