Beta 25 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b25.zip
- added a preference for selecting whether order titles in the outline view should show buyer name or listing title (and additionally order date)
- creating scheduler events from a lot of listings is faster now
- added menu command for editing variations
- added menu command for editing condition details
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
