Beta 26 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b26.zip
- the count down in the scheduler window does automatically update now (thanks @fonky1)
- fixed an issue in the scheduler where errors received from eBay while starting a listing weren’t shown (thanks @fonky1)
- fixed a crash when invoking undo after you selected a different listing after a change
- fixed an issue where the media browser would shrink in size after every restart of GarageSale
- fixed a crash when importing listings exported to file by older beta versions (thanks @vintagecrave)
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
