Beta 28 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b28.zip
- fixed a few bugs in the “can duplicate (and optionally move originals to the trash) when creating scheduler events from already started listings”-feature introduced with beta 27
- fixed a crash when opening the design popover window
- several improvements in the scheduler window
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
