Beta 30 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b30.zip
- reduced memory usage by unloading unused database items
- works around an OS X bug that leads to crashes when entering a malformed number into an popover
- fixed an issue to led to a larger main window every time you switched the active section
- faster selection changes in the outline view when a lot of items are selected
- when dragging items from overview mode into the outline view, all selected items are dragged instead of only the visible ones
- fixes empty preview problem when an item attribute was not filled in
- improved support for “classified ads” listing format
- “Revise Listings” and “Stop Listings” commands in listings mode now operate on the correct selection (outline view vs. overview mode)
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
