Beta 31 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b31.zip
- greatly improved index system in the database for faster lookup operations. This requires a migration of your library. Make sure you have backup of /Library/Containers/com.iwascoding.garagesale7, before running this version. Older betas will not be able to open your database after the migration.
- faster starting of listing, which are linked to inventory items trough their SKUs
- current inspector tab remains selected when changing the selected listing on non-US sites
- fixes hangs in variation panel when editing SKU field
- fixes checkmark in the ‘Listing View Mode’ submenu
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
