GarageSale 7 Beta 34 Released
Beta 34 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b34.zip
  • improved feedback when canceling listing starts in Launch Control window
  • multiple listing drafts from ‘GarageSale Scout’ on iOS can be imported at once
  • fixed shrinking main window on startup
  • the ‘Verify Listing’ command in the Listing section’s toolbar is available again
  • fixed calculation of Total amount in Order section
  • leaving feedback for multiple orders at once works again
What’s new in GarageSale 7
  • can import listing drafts from the GarageSale Scout app on iPhone
  • can automatically generate SKU for your variations
  • much more
Upgrades and Pricing
Migrating from GarageSale 6
  2. Quit GarageSale 7
  4. Restart GarageSale 7
What’s still missing
  • localized user interface for languages other than English
  • a user manual
So where does one find this “Scout” app? Is it still in beta or something? I keep seeing mentions, but very little info.
you can send an email to garagesale@iwascoding.com and request access to the beta version of GarageSale Scout. It is a iOS app, so you need an iPhone/iPad, too. You can also send a private message with your email address/name to me and I will add you to the list of beta testers.
Hello, I had to force quit using my 6 version because its not responding anymore- I did try and use the 7 version with works fine but now it wants me to pay $39.99? I thought there was a upgrade to previous purchases?
thank you
Melissa
Hi Melissa,
GarageSale 7 is a paid upgrade from any previous version of GarageSale. The upgrade costs €/$ 19.99. During the public beta phase the GarageSale 7 upgrade is available for €/$ 16.99. Upgrade licenses are only available from within GarageSale 7 (choose “Buy License…” from the “GarageSale” menu).
If you don’t get an upgrade option there, click on the “Enter previous license” link to enter your GS6 license. You should then see the upgrade option.
Kristian,
If it were my choice id like to get the program I paid for originally to work? Ive contact you all numerous times in the past to help me and now I’m stuck upgrading to 7, is that correct? Now 6 is not working at all and last time I posted, someone stated that the case was closed… Not sure what to do now, other that just use Ebay directly? If you don’t mind getting my original license number so if I choose to upgrade and ill have it on hand… I can message you my email if you wish
Thank you
Melissa
I’m not sure whether this has already been addressed, but I don’t recall seeing it.
I had a Scheduler event set to start five auctions last night. The two that had warnings during verification did not start. One of the warnings was minor and the other was incorrect:
  • ValuePack upgraded to include Gallery Plus for the same fee. (the minor one)
  • Condition is required for this category. (the auction did include condition details)
I started both items manually and they worked fine. The ValuePack warning did show up again, but there was no sign of the condition warning.
Let me know if you’d like logs or anything.
Hi Melissa,
You can request your GarageSale 6 license at any time in the “Lost Licenses” section on our website:
http://www.iwascoding.com/Contact/index.php
Hi Bretterson,
you’re referring to the “Condition details” but did you also check the “Condition” settings in the Options Inspector? (Where you can select “New”, “Used” and so on…)
Hello,
I have the b29, can I do the update to the 34?
Of course, simply use the built-in update mechanism or download the latest beta version from here.
Yep, I did. It is and was selected. I don’t think you can even enter details without having a condition selected.
  • Brett
