Beta 40 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b40.zip
- added 4 new designs
- fixed a bug where certain transactions weren’t included in a report, even though they occurred in the report’s time frame
- fixed a performance bottleneck when updating smart groups after listing and order states were downloaded from eBay, that could cause GarageSale hang unexpectedly
- when creating new listings form inventory items quantity, item cost, and price of the inventory item are copied into the listing
- added additional commands to the ‘Orders’ menu that were only available from the toolbar before
- added a separate preference for downloading eBay messages under Preferences > eBay > Advanced
- improved profit calculation when insurance feature is used on eBay France or Italy
- holding down the option key while choosing “Sort by title” from the listing section’s outline view context menu sorts listings in reverse order
What’s new in GarageSale 7
- added support for specifying shipping insurance cost on eBay Italy and France
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- localized user interface for languages other than English and German
- a user manual
