Beta 42 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b42.zip
- fixed a bug that prevented smart groups from being updated when new order information was received from eBay
- removed support for EPS watermark option, which is no longer offered by eBay
- removed support for ‘Get It Fast’ option, which is no longer offered by eBay
- the Media browser window is automatically hidden when a popover is shown to prevent overlapping
What’s new in GarageSale 7
- added support for specifying shipping insurance cost on eBay Italy and France
- added 4 new designs
- when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- localized user interface for languages other than English and German
- a user manual
