Beta 44 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b44.zip
- fixed another performance bottleneck related to smart group evaluation
- GarageSale will now automatically delete orders that have been merged into a new order using the “Combine Orders” command on the eBay website
- when a 'use rate table" checkbox is enabled in the shipping settings, package weight can be entered and is transmitted to eBay to support weight-based rate tables
What’s new in GarageSale 7
- a new custom database engine, which deals better with large amounts of data and allows us to adapt to eBay changes more quickly
- added support for specifying shipping insurance cost on eBay Italy and France
- added 4 new designs
- when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- localized user interface for languages other than English and German
- a user manual
