The first beta version of GarageSale 8.0.6 is out and can be downloaded from this link
https://downloads.iwascoding.com/downloads/GarageSale_8.0.6b1.dmg
What’s new in GarageSale 8.0.6
- Synching: holding down the Option/Alt key while choosing a conflict resolution (local or remote) in the Conflict panel, applies that resolution to all conflicts
- Synching: improved performance when opening Conflict panel
- Synching: fixed possible crash when importing received data from sync server
Thanks for using GarageSale!
