GarageSale 8.0.7 is out and can be downloaded from the link below or the built-in updater
https://downloads.iwascoding.com/downloads/GarageSale_8.0.7.dmg
What’s new in GarageSale 8.0.7
- popup menus for shipping services now show the last 5 most recently selected services at the top
- bulk search & replace window remembers the last used search scope (entire library vs. current selection)
- added commands for hiding listings with or without errors to the Launch Control window’s context menu
- GarageSale now permits using more than 25 attributes in a listing
- fixed a bug in the Attributes panel, where previous edits where lost once you removed a specific, while the panel was not torn-off
- fixed a bug where the Preview would not immediately reload when the Attribute panel closed
- Synching: fixed a possible crash
Thanks for using GarageSale!
