Beta 8 of GarageSale 8.0.8 is out and can be downloaded from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_8.0.8b8.dmg
- the panel that comes up when you drag an image onto another image in the preview (Do you want to replace or add an image?) now has a checkbox for remembering your decision and not showing up again
- when exporting your orders to a CSV file, commas are correctly escaped
- revising auto-accept and auto-decline prices works when the “Best Offer” option has been selected from the list of properties in the Revise Panel
- category paths in the category search view are truncated at the beginning, not the end
What’s new in GarageSale 8.0.8
- added 6 hours, 12 hours, 1 day, and 1 week as additional durations for automatic Order update in the Order preferences
- all settings from the Code Editor preferences panel are now saved
- the “Show Image” command in the Preview context menu works again
- shipping service can be hidden from the shipping service popup menus via the “Show/Hide” services command at the bottom of a menu
- the “Create Link” button in Preview format toolbar can be used to modify existing links
- the “Stop Listing” panel remembers last selected reason for ending a listing
- inventory items no longer forget their costs are sales prices when set to “0.00”
- double-clicking a linked listing in the inventory section shows that listing again
- fixed a bug with importing JPEG images that use a rotation “flag”, which caused the image to appear in the wrong orientation in GarageSale’s preview mode and on eBay
- the preview no longer shows the “Generating…” message forever, when an error occurred while GarageSale tried to download category data from eBay
- fixed several issues in the code for downloading attribute suggestions from eBay
- deleting an image from in Preview mode now triggers a reloads the of Preview
- altering the SKU field in the variations panel no longer erases the bar code of that variation
- the bid count label in the outline view updates when new bids are received
- crash fixes
Thanks for using GarageSale!
