GarageSale 8 Beta 44 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b44.dmg
- fixed issue with computing number of already uploaded listings in the current month
- fixed possible crash during GarageSale 7 library import
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
