GarageSale 8.0 Beta 47 Released
GarageSale 8 Beta 47 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b47.dmg
  • no longer offers duration other than GTC for fixed price items
  • prevents an error in the ‘Import from GarageSale 7’-process caused by GS 7 still running
  • updated German localisation
  • Synching: Conflict panel can display more types of conflicted properties
What’s new in GarageSale 8
  • drastic performance improvements for search, smart groups, reports, updating data from eBay
  • completely reworked design templates
  • database synching between Macs, more info available here
  • popovers can be detached and retain their position and size between sessions
  • maximum image size when using GarageSale’s image hosting is now 1600x1200
  • improved UI feedback when using multiple connections and launch interval options
  • bulk “search and replace”
  • adds support for ‘Dark Mode’ appearance on macOS 10.14 Mojave
  • added ‘days Remaining’ smart group rule to the listing section
  • added warning about upcoming GTC requirement for fixed price listings
  • revised selection behaviour, so items selected in the outline view get immediately selected in the overview (middle area of the window)
  • added a popup to the listing overview for quickly filtering items by state
  • colors for the listing state icons be be configured via General preferences
  • added option to launch control window for using multiple connections when communicating with eBay
  • GarageSale Pro subscribers can upload up to 50 images per listing when using GarageSale’s image service
  • users can print customisable packing slips and shipping labels from eBay orders
  • added minimum listing interval option to launch control window
  • implemented a work-around for broken drag and drop from Apple’s Photos application
  • size of thumbnail images can be changed in image overview mode and listing editor mode
  • when running macOS 10.13, a faster panel is used for importing images from Apple’s Photos app
  • Improved AppleScript
    • Added values for order transactions
    • Can now upload tracking number via AppleScript
  • Smart Groups can be sorted
  • more filter and table view options in My eBay import panel
    • filter by auction/BIN
    • added column sku and end date
  • support for file images in XML import
  • can set title/category from catalog product (product search popover)
  • added preference to show buyer’s eBay account name in orders outline view
  • users can manually share started listings via FaceBook/Twitter
  • added preference to display colored background in listing mode outline view
  • added “Create Invoice with GrandTotal” command
  • when using no design, updated HTML code used for displaying your images below your description
  • started working on new “Pull changes from eBay”, which let’s you import specific changes you made to your listings on eBay back into GarageSale (not done yet)
  • improvements to AppleScript execution speed
  • when exporting multi-item orders to GrandTotal for invoicing, the shipping cost should be correct
  • shipping service table column in shipping options panel is resizable
  • added advanced eBay preference to specify the attributes panel’s behaviour when specifics are empty (insert suggested, insert required, insert no attributes)
  • added support for ‘Continuity Camera’ feature on macOS 10.14 Mojave
  • added menu commands to cycle focus between different parts of the main window
  • shows buyer phone number to order inspector
  • -order section: buyer name and address are now a single field for easy copying
  • added “Show Main window” menu command in case you accidentally closed it
  • shows number of verified listings in Launch Control window
  • added AppleScript command (and example script) to remove images from listings
  • when adding new groups, name fields in outline view get selected for editing
  • added advanced eBay preference setting to only perform local verification in LaunchControl window (and prevent verification with eBay)
  • error message for eBay error 240 shows additional error reason, if sent by eBay
  • eBay Message templates: fixed [[totalPrice]] and [[shippingCost]] macros to include billing shipping cost instead of the private “actual shipping” cost field
  • re-added support for the ‘Private Listing’ flag
  • removed outdated buyer requirements no longer supported by the eBay API
  • added “Move Selected Items to” command to “Edit” and outline view context menu
  • user can choose between multiple default footer layouts in Preferences panel
  • GarageSale performs certain eBay data update operation (GetSellerList) on 4 concurrent connections
  • ‘Activity Viewer’ window opens automatically on startup, if it was left open before
  • moved SKU field to first tab of Listings inspector
Synching
  • GarageSale 8 requires OS X 10.12 or later
OUCH! I have still been using “30 days” for all my Fixed Price Listings. (Hoping that eBay will reverse this change!) I see that now they are “automatically” converted to GTC. OK…
Sooo… In Smart Groups, for the Duration trigger, what is the textual value for “GTC”???
How do I test for GTC, or NOT GTC in a Smart Group Duration field? This field is a TEXT field, and the “values” I have been using are “30”, “7”, “5”…
Thanx,
Have you tried putting in „1000“? Don’t have access to the code at this moment. (I’m at the eBay Developer Conference at the moment)
Just did. That works!
Thanx!
Anybody else having a problem creating Smart Groups? Every time in the latest and the previous beta it crashes.
Thanks for letting us know. I’ll check the crash database for these crashes.
Here I have some suggestions/possible problems that I collected during last weeks:
  1. “use multiple connections” in launch control when starting listings is not always remembered. After a little time it is reset and have again to select the option.
  2. [from whenever I use GS] why can’t I select a list of listings if I press shift and click between images? I expect listings in the middle to be selected, but they are not. If you switch to list view it works: see VIDEO
  3. there must be some issue in smart folder for watchers. This is months it does not update (also clicking on or doing another one). The right one is about 1100, not 700…
P.S. I know there must be tons of stuff with synch, this is just to focus and point definitely some issues that otherwise I risk to forget to report…
I found your crash log, but it’s not clear why the crash is happening at your place. We added an extra panel to show additional information in case that special condition is triggered again in Beta 48. Please give that one a try once released.
Ok in 48 it says the following:
“Caught exception will configuring row for key startedAccountID, type accountID”
Once I click ok it will let me create the smart group. But happens every time.
That’s strange. Do you have any eBay accounts in GarageSale authorised?
This is probably too obvious but could it be that one of your eBay token just needs to be refreshed and/or you have to select “Update All Listings” from the Listing menu?
I tried the “Watcher” smart group rule here and for me it works as expected sot it doesn’t seem to be a general issue.
I fiddled around with the code a litte, can you check if this version solves the problem:
http://downloads.iwascoding.com/downloads/GarageSale_8_2019-07-05.dmg
Hello Kristian,
unfortunately this is not the problem. I have just updated the token, deleted the smart folder and recreated from zero, it still shows the same number as before. There must be something wrong, but I don’t understand what…
Thank you
Ok thanks. There were two accounts in preferences. It wasn’t signed in and the good one was set as default. Anyways I deleted the duplicate bad one, refreshed the token and it works now. Thank you for helping!
