GarageSale 8 Beta 52 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b52.dmg
- fixes a critical bug in the GarageSale 7 Importer module that could lead to data loss (e.g. ‘Ghost Listings’) at a later point in time. Please use the new ‘Fix Reference counts’ debug option (hold down the Control key when starting GarageSale), or re-import your GarageSale 7 library
- fully updated Italian and French localization
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
