GarageSale 8 Beta 53 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b53.dmg
- performance improvements when duplicating listings
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
