GarageSale 8 Beta 59 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b60.dmg
- GarageSale is correctly signed for upcoming MacOS 10.15 Catalina
- when listings fixed price items on eBay Motors, all valid durations are offered again
- after dragging items from ‘overview mode’(middle column) to the outline view, the overview is correctly updated
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
