The popup menu is NOT sorted alphabetically when I open the Smart Group editor window with the <option> key held down. Using macOS 10.15.6 (19G73). See photo below.
BUT… If I press the <option> key after the Smart Group editor window is open, the “+” buttons change to “…” buttons and seem to add “nested” operators when clicked??? I never noticed this before. Is this intended behavior? If so, it could make the Smart Groups much more powerful. See photo below.
I have to agree with @Neal. Holding down the option key has no effect on the list. T see no advantage for the “…” however. It adds random attributes with no pattern or guess to what it will add. The copy I have is 8.1.1(1233). As soon as I downloaded this beta I got notice that 8.1.1 had downloaded and wanted to open, to which I replied “later” so I could try the beta version. Was this intended behavior or just an update after the beta release?
Nice improvement! Question, Could the beta versions have the file name, ex “8.1.2 b2 (1235)” on it so when dragging to the Applications folder it doesn’t overwrite a version already there?
I like being able to “back up” to a working version if the beta has a issue with out downloading an old copy from the server. I have GS7, GS 8.1, and the current beta version in my Apps.
