the final version of GarageSale 8.2 is available for you to download and test from this link, or through the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.2.dmg
What’s new in GS 8.2
- improved performance when selecting (smart) groups with a large number of listings
- improved performance when evaluating smart groups with large number of listings
- improved performance when loading search results
- improved performance when moving a larger number of items to the Trash
- inspector is no longer limited to editing a maximum number of 5000 listings at the same time
- fixed a crash when moving an item to the trash that had an invalid link to its parent group
- fixed bug that could prevent a single order from appearing in a Report
- Car Parts: multiple found vehicles can be selected by holding the shift key, and added to a listing by double-clicking
- Car Parts: compatible vehicles can be deleted from a listing
- Smart Group editor: the property popup in the will be sorted by alphabet, when the option key is held down when the Smart Group editor is opened
- performance improvements when using a large number of listings with the Auto-Cancel option
- when generating a label with Endicia, the shipping carrier for the selected order is set to “USPS”
- smart groups containing rules for amount values (e.g. ‘buy it now price’ = 64.99) now work correctly
- the ‘Add New Smart Group’ command from the ‘File’ menu is available even when outline view doesn’t have the keyboard focus
- shipping options popover doesn’t forget current changes when being torn off
- user comment field in Listings mode is searchable
The GarageSale team
