GarageSale 8.3.1 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.3.1.dmg
What’s new in GarageSale 8.3.1
- fixes launching problems on older MacOS versions
- runs natively on Macs with new Apple Silicon chips
- text snippet macros are now supported in the ‘condition description’ field
- Bulk Search & Replace panel: added an ‘Exact search’ option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
- icons for listings in the Main window outline view should reflect listing state changes more quickly
- Shipping options panel: package weight can always be edited when ‘calculated shipping’ is used for either domestic or international shipping
- category popover shows category tree version in sprocket menu when option key is held down
- fixed a crash when updating incomplete local listings with data from eBay
The GarageSale team
