GarageSale 8.3.5 Beta 4 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_8.3.5b4.dmg
What’s new in Beta 4
- Synching: Fixed a bug that prevented a Mac from uploading data to the sync server, when a user created a new conflict by editing the local database while the Conflict resolution panel was already open
What’s new in GarageSale 8.3.5
- programmatically selected entries in the main window outline view are scrolled to the middle
- worked around an eBay error when leaving feedback
- the ‘Time Remaining’ column in the Listing overview table is updated periodically
- the Image Markup editor works again on MacOS Big Sur
- Attributes Panel: combo boxes don’t contain duplicate suggestions for certain attribute types
- added an “Open GarageSale Community” command to Help menu
The GarageSale team
