improved performance (less beach balling) when determining what images to delete from a custom FTP or WebDav image server
multiple images can be selected, dragged, and reodered in listing Editor mode
What’s new in GarageSale 8.3.5
programmatically selected entries in the main window outline view are scrolled to the middle
worked around an eBay error when leaving feedback
the ‘Time Remaining’ column in the Listing overview table is updated periodically
the Image Markup editor works again on MacOS Big Sur
Attributes Panel: combo boxes don’t contain duplicate suggestions for certain attribute types
added an “Open GarageSale Community” command to Help menu
Synching: Fixed a bug that prevented a Mac from uploading data to the sync server, when a user created a new conflict by editing the local database while the Conflict resolution panel was already open
This new feature is quite useful and helpful, IF the selected listing item was NOT already visible on the screen…
But, for me, it is very annoying if the item was already visible, and I’m relisting it for example, and then I hover over it’s parent folder waiting for it to finish so I can close the parent folder, and then the item, and parent folder, move to a new location in the list…
Can you just do the new code only if the item was not already visible???
