text snippet macros are now supported in the Condition description
category popover shows category tree version in sprocket menu when option key is held down
What’s new in GarageSale 8.3
runs natively on Macs with Apple Silicon chips
minimum macOS is requirement is now raised to macOS 10.14 Mojave
fixed a crash when updating incomplete local listings with data from eBay
Bulk Search & Replace panel: added an “Exact search” option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
I just programed some smart keys to easily empty the deleted items. I look at he file once a day to make sure nothing running is in there and hit the empty smart keys and get rid of them. I thought maybe you were keeping them for later use.
